I used various sized and shaped wire wheels on a pneumatic die-grinder to remove the surface rust in the boxes and also to remove paint from all of the crevices and factory spot welds. When I smooth a line weld, I start out with a few very aggressive, even, and fast passes with a newer 60 grit flap disc on a 4 1/2" grinder (Concentrating strictly on the weld itself). Then I switch to an old well worn 60 grit flap disc. My passes are still aggressive and even, but with a lot less pressure. When the weld is all but smooth, and all I can see is a faint outline of the weld on both sides of the joint, I make one or two more very light, even passes. Then, I switch to a cylinder style 80-120 grit flap roll (not sure of the proper name) on the same pneumatic die-grinder and start making even strokes to blend the weld and surrounding metal. I could have done a better job smoothing on the floor and kick panel welds, but I reasoned that they will be completely hidden and the extra weld could only make the joint stronger. The important thing to remember when welding and grinding a sheetmetal butt-joint smooth, is that it is imperative (in order to achieve a strong weld), to leave a gap of at least the thickness of the wire that you are using. This is to ensure that once the weld has been smoothed, there is still ample filler metal holding the joint together
. For the plug welds, the same treatment is used, but I skip the new disc and start with the well worn one instead. After the plugs are smoothed, wherever there were factory spot welds, I duplicate with a flat-tip Sterrett punch (of according size) and whatever hammer I have lying around. In my opinion, this gives it a very original and unmolested look.
One thing to keep in mind, if you are too aggressive with a grinder, it is very possible to warp the metal.
Right now I am in the process of smoothing the firewall. It's a factory a/c truck, but for simplicity and space, I am going with an Old Time Air a/c system. Their system requires only one 3" hole in the firewall. It comes with a bolt on cover to hide all the extra holes and passages, but I wanted something that looked a little cleaner. This is what I did last night...............
Tomorrow night, I hope to have the rest of the firewall stripped...........
