If you're not planning on crossover, then you can only move the axle forward so much (and 2" is probably too much).
I'm just starting to wonder what portion of the "scary flexy/wobbly" ride with 52's is from the extreme shackle angle. Anybody with B-52's ever test this theory?
What's wrong with locating the front spring hanger directly under the body mount (with 52s) to move the front axle forward 1" and get a slightly better shackle angle than stock?
People seem to say that 30 degrees from vertical is a good shackle angle and 45 degrees is too far, but I've never seen math to reinforce this. It makes good logical sense that the rig will handle bumps better with some shackle angle since the spring is moving in the same direction the wheel wants to move.
shackle angle is not just about a number. It depends on the arch of your spring. A flat spring can have a whole different angle than one with a good amount of arch. and a harder spring whith alot of arch would need a different angle.
