WY Allison 1000 Transmission
coloradoblazers
WY
Pulled this from a 2001 GM CCLB 4x4 with an 8.1L. truck had just under 200k.
It was running when pulled, owner hit a concrete block in his field.
Asking $400 OBO
Located in Laramie, WY.
Two questions.....
1- what type of transfer case was this bolted to ?
2- Is the bellhousing pattern unique to the 8.1 block,,, or is it the same as all standard MK IV big blocks?
My answers are below...
Two questions.....
NP263 (29 spline)
I believe it is the same as most GM blocks. @Larry could probably tell you if I am wrong...
Thanks for your interest, let me know if there's anything else I can help with...
