I was told by one of the vendors on this site that the company that makes Alloy USA's axle shafts also makes Yukon's shafts. He said everything except the black coating on the outside is the same. The Alloy USA shafts are coated the Yukon shafts are not. He said the uncoated shafts are better because you can see if they are cracked.
I asked him if you can use the Yukon stubs with the stock inners and he said you can.
Then I asked him about this.
He said he hasn't had any of his customers complain about it and they (Yukon and Alloy USA) are the same.
I would like to buy Alloy USA shafts but this is what they are saying "We do not have an exact eta for these shafts right now. I know they are in the works but it will be no less than 30 days before we see them."
The vendor told me Yukon was buying all of the axles so Alloy USA couldn't get any.
What do you think of all of this info? I don't think I believe all of it.
How many people have had the problem Georga Gabe had?
I broke a 30 spline Dana 60 stub shaft the last time I was playing in the mud. What should I do?
Thanks,
Mike
Georga Gabe said:I tried to use the stock 35 spline inner with the Yukon Chromo 35 spline outer to keep from buying the outer twice. It does NOT work... the ears are so much thicker on the chromo shaft that they will not articulate into the corresponding pocket on the stock shaft. So your steering is severely compromised.
Thanks,
Mike
,which ever they are, is alot different than $280 for Alloy USA stub shafts shipped to my door.
