goalvanny
Registered Member
so iwas getting the truck ready to wheel in the pines and ran into problems.the alternator went bad and i put in a factory 63 amp one. with the wipers and electric fan it works fine but when you put the lights on it only last for a few seconds ten drops to 12 volts ok so i tried the lights only and had the same problem. belt is not slipping so i know thats not it. just wondering what you guys think.
i rewired the truck when i had a fire in it a while but never had problems till now. do i have to hook up both spade terminals on the alt or not i only have the one hooked up. and what is the cheapest easiest swap for an alt like in the 90 ir 100 thanks sorry for alll the questions
o and alll the lights are factory and i dont even have a dash so thats not a problem either
