chevy_addict
diesel4me said:I know how a wire a house,lights,motors,etc--then I bought a 3 phase compressor!!!![]()
--still havent figured that thing out!--its got more wires than I can handle--and I dont like playing with 220V!!.( and I cant run it here anyway,no 3 phase current in on my street!).
Do a google search under "rotary phase converter". You can get 3 phase 220 out of single phase 220
. I run a starter wire down there, and that is just for the starter. Then I re-did the primary loop as I described above (possily in overkilll, or at least voltage redundancy). It was reccomended that I use the original routing to the firewall junction block, back to the battery method to avoid any charging issues. It has worked fine so fat.
