Hi all, looking for input on radiators. I’m in Northern California and running in 100 plus degree weather.
Currently have a Chinese 4 row aluminum (not sure of tube size) with my full size AC condenser and 9” trans cooler in front of that.
With no AC, it runs 190 pretty stably (160 thermostat), but with the AC on and idle, it creeps up to 210 and beyond. Not sure where it’s stop. And the truck does not easily recover once back on the freeway.
Stock 7 blade fan with stock shroud with stock fan clutch.
I got such mixed reviews from the people I’ve talked to, I thought I’d reach out. Is it better to have an aluminum three row with 1 inch tubes or a four row brass and copper traditional half-inch tubes? I mean the coolant can only go as fast as it can through the thermostat so I’m not sure how much tube size matters (not what she said).
Anybody running in hot weather with AC? My goal is to be able to idle on 100° heat with my AC on.
Thanks!
Chris
Thanks!
Chris
If you read that here or on gmsquarebody.com then the dually reference was 99% about
. For example, it's 58 degrees here now, all the engines run cool, A/C is more efficient and the engine makes more power, so win/win.
