Eric M.
This isn't exactly K5 or 4x4 related, but, it's a second generation truck and most of you know them in and out.
I do construction and bought a beat up 80 1 ton dually 2wd dump truck a few years back. Thought it would make a fun project and give me a dump truck which I desperatly needed.
Here are the specs:
-1980 C30, dually, 12 foot dump bed with 4' sides.
-350 w/ 100K original miles. Tuned up, rebuilt carb, runs good.
-Rebuild Turbo 400 (was stick, but too many of my guys can't drive a stick)
-Front suspension and steering all new, from springs to bushings, from tie rods to steering box.
-New 1 ton rear leafs with 2 extra springs each side.
-I'm running the shortest tires I can find for torque and better braking, load range E.
-Brakes are all new, from Hydroboost on out. Running carbon kevlar pads in front.
-14 Bolt FF CC rear with 4:10.
My question - The GVWR of the truck 10,000, empty it weighs 7700. Not much of a load capacity considering it has a 12' x 8' x 4' bed. This truck, loaded, tips the scales at the dump at 13,000 to 15,000 pounds.
Am I pushing it? Do you think something is going to break? The engine has to work to move the truck, but it never gets past 200 degrees and I'm not driving dangerously slow on the freeway. The brakes work well ... common sense says keep a lot of room between you and the car in front of you.
For those of you thinking I'll get nailed by the highway patrol, when I looked into that, I was told I needed a weight sticker on the side, when I went to the DMV they asked what I wanted, I told them 10K and they told me the smallest they had was 15K and gave it to me. My sticker and registration now say 15,000 pounds.
What do you think?
Eric M.
Here are the specs:
What do you think?
Eric M.
There are bags on it too.
