Can you share part numbers of what kit and such you used? More pics of underside? Would love to add on my k5 and remove the static hoops i haveView attachment 486773 I did they turned out great. Lots of planning
@Engineered Vintage will these work with crew cabs as well? Or will the bracks be different because of frame size? (When will those be released?)
I will be a buyer eventually for a crew cab set.
I will have a suburban body on a crew cab frame, using a suburban tank in back, so that wont be an issue for my build (but i know standard CC will have that issue. I would be happy to be ginny pig for brackets on crew cab frame. Im scared to ask for one off.The Suburban kit will not work with crewcabs due to frame size and side saddle gas tanks. I don't have ETA on release of crewcab version.
Full-size Blazers/Jimmy are up next
I thought i had read somewhere they are tricky because of the rocker boxes in the full verts, but maybe a non issue with them mounting to frameI'll be waiting on the 73 - 75 full vert Blazer / Jimmy version. That will make the wifey happy.
Yeah, that's the problem, frame mount would be ideal.I thought i had read somewhere they are tricky because of the rocker boxes in the full verts, but maybe a non issue with them mounting to frame
I have been looking at the areas under the doors / frame on 73-87/91 trucks a lot lately. I'm blown away by the variations in frame thickness, height, and differences in underneath cab.I thought i had read somewhere they are tricky because of the rocker boxes in the full verts, but maybe a non issue with them mounting to frame
Good thing you know so many people with all the trucks.I have been looking at the areas under the doors / frame on 73-87/91 trucks a lot lately. I'm blown away by the variations in frame thickness, height, and differences in underneath cab.
And then throw in rocker boxes in the 73-75 blazers and cat exhaust shields in later rigs and diesel fuel lines in the mid-80s - all kinds of fun! (or maybe a different F word??!) LOL
you are the best @kennywGood thing you know so many people with all the trucks.
I am pretty sure you can use the same brackets from the suburban.I’m not there yet (perhaps next year?, depending on speed build goes) but would really want your brackets, look stout and clean. Hopefully there is a way to get some made for CC frame. I’ll drop you a pm
