AMP running boards
I am pretty sure you can use the same brackets from the suburban.
It's the same once the saddle tanks were removed
Suburban frames are flat under the seating area. Crewcab will rise under rear passenger seat and be a taller frame (8" vs 6" height).
Well I guess I don't know how he attaches the brackets to the frame but I am sure you can bolt them to the side of the frame which means you can still do it.
Ben can talk to his design with more detail as I have not seen it yet. But he did tell me they are designed not to require drilling holes in the frame.
Our goal is to not drill (or minimize drilling) into these Vintage trucks as much as possible. With that, our mounting brackets for crewcabs will likely be different than Suburban brackets due to the height difference in frames as well as (as @kennyw mentioned) the crewcab frames bump up near the side saddle gas tanks.
Our Suburban kit for 81-91 Suburbans is available now on our website. Kits for 81-91 Blazers & 81-91 Crew Cabs are coming soon
https://engineeredvintage.com/collections/step-kits
