Amsoil Products
Midwestern4x4Parts
Frankfort , IL
I offer
-Oil ( Gas , Diesel , Marine , Motorcycle , and 2 Stroke)
-Oil Filters
-Bypass Filtration
-Air Filters
-Grease
-Wipers
-Fuel Additives , and much more..
Let me know what you need , and how I can help.
5w50? You sure that's right?
How many Qts , and with or without a filter? (If so need application)
10 to 12 qts , i saw 5w50 once awhile back. I liked it due to the wide temp range... where i plan to move summers 100+ and winters below 0. i figured it would be the best.
It would be going in to a 87 350cid K5. .030 over etc. Oil cooler , twin oil filters etc.
This is the Info I have for your truck . Amsoil Doesn't carry 5w50. As you can see here are the recommendations.
Please click on any of the product links below for more information or to make a purchase.
1987 CHEVROLET TRUCKS BLAZER 5.7L 8-cyl Engine Code [K] FILTERS
Oil Filter:EAO27Absolute Efficiency Oil Filter
Oil Filter:51061WIX 51061 Oil Filter
Oil Vapor Filter:42998WIX 42998 Breather Filter
Air Filter:EAA31Absolute Efficiency Air Filter
Air Filter:42098WIX 42098 Air Filter
Fuel Filter:33481WIX 33481 Fuel Filter
Trans Filter:58897WIX 58897 Trans Filter [1]
1. 4 Speed
NGK PLUGS & WIRE SETS
Plug.................IXIRIDIUMUR5IXNGK7177
Plug.................VPOWERUR5NGK2771
Wire Set..........WIRESETRC-GMZ037NGK51241
TRICO WIPER BLADES
Blade ClassDriverPassengerRearNEOFORMT16180
T16180
EXACTFITT182
T182
WINTERT37180
T37180
OKTANE18 inch
18 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Above 0°F......10W-30
Above 39°F......30
All Temps......5W-30[1]
Below 61°F......5W-30
Manual Transmission,.....GL-5
80W-90, 80W[2]
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,4-SPD W/ OD.....GLS[3]
Synthetic Automatic Transmission Fluid
Automatic Transmission,THM700-R4.....AF6
Automatic Transmission,THM400.....AF6
Differential, Front .....GL-5[4]
All Temps......80W-90
Severe Gear 75W-90
Differential, Rear .....GL-5[4]
Severe Gear 75W-90
Transfer Case,.....GLS[5]
Fluids
Power Steering Fluid.....PS
AMSOIL Universal Synthetic Power Steering Fluid
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. SAE 5W-30 is preferred.
2. 1984-90, In CAN use 80W only.
3. GM recommends Part No. 88861800 (Canada 88861801)
or equivalent for manual transmission, transfer
case applications.
4. 1984-90, In CAN use 80W only.
5. GM recommends Part No. 88861800 (Canada 88861801)
case applications.
CHASSIS LUBRICATION
Two-wheel drive
8-12 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
4-9 Fittings, 0 Plugs..........LB
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Cooling System, with AC Initial Fill..........19.0 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, W/O AC Initial Fill..........17.0 quarts
Automatic Transmission, THM700-R4 Initial Fill..........5.0 quarts
Automatic Transmission, THM400 Initial Fill..........4.3 quarts
Automatic Transmission, Total Fill
4 speed THM700-R4..........12.0 quarts
3 speed THM400..........11.0 quarts
Manual Transmission, 3-SPD..........3.0 pints
Manual Transmission, 4-SPD..........8.0 pints
Differential, Front..........4.0 pints
Differential, with 10.5 ring gear Chev Rear..........7.2 pints
Differential, with 10.5 ring gear Dana Rear..........5.5 pints
Differential, with 12.25 ring gear Rear..........14.0 pints
Differential, with 8.5 ring gear Rear..........4.2 pints
Differential, with 9.5 ring gear Rear..........5.5 pints
Differential, with 9.75 ring gear Rear..........5.5 pints
Transfer Case,NP208..........10.0 pints
Transfer Case,NP205..........5.1 pints[2]
1. Add extra oil when replacing filter. After
refill check oil level.
2. With NP205 fill no higher than 1" below filler plug.
TORQUES
Oil Drain Plug.....20 ft-lbs
Transfer case
Fill Plug.....18 ft-lbs
Drain Plug.....18 ft-lbs
Transfer case NP205
Fill Plug.....40 ft-lbs
Drain Plug.....40 ft-lbs
Transfer case NP208
Manual Transmission 3-SPD
Fill Plug.....13 ft-lbs
Manual Transmission 4-SPD W/ SLC
Manual Transmission 4-SPD W/ TLC
Fill Plug.....17 ft-lbs
Drain Plug.....17 ft-lbs
