handloader90
Building!
I'm looking into buying a 16 gallon fuel cell here soon and all of the fittings on all of the fuel cells that I've seen are -6AN or -8AN. I use NPT fittings on my mechanical fuel pump and carb. I don't want to run fancy AN steel braided blingy fuel line. Just good 3/8" rubber hose for me.
How do I PROPERLY adapt these fitting to accommodate 3/8" fuel hose? I haven't been able to find any kind of 3/8" NPT barb fitting that is threaded for AN.
My '76 K10 still has the factory saddle tanks on either side. Is the fuel pump for two tanks different than the fuel pump would be for just one tank (fuel cell in my case).
Is a return line necessary, beneficial or a good safe measure? If so, please explain.
If I go to one of the common parts stores will they have a SBC mechanical fuel pump without a return line fitting for me to purchase?
