I love lists....to bad I can never finish one..![]()
Things will probably be skipped or half assed but o well, running the dunes with everyone will be worth it.
More stuff to add
Go pro mount(gonna video everything)
Diff breathers
with stock crossmember?
Putting this here to help me finish before the get together.
Mount and wire second battery - Done
Mount co2 tank - Done
Mount fire extinguisher
Mount tool box
Finish center console
Fix trans dipstick leak - hopefully done
Install windshield
Finish welding front bump brackets - Done
Fab rear bump brackets
Fix power steering leak.
Rough align front end
Get new tags for plate - Done
Check all fluids
Torque every bolt
Pack tools
Load rig on trailer
ill snag you the one i got hanging on the wall in the garage, came off my motor. only had but a few thousand miles on it. its an aftermarket stock replacement but its like new. no money needed, its yours. that 208 you mentioned a while back, that come from behind a 700r4 or a t350 by any chance? decided to go with a built 700r4 for my truck just need to pick up a p side drop 208 or 241...
Shoot, just thought of something. Is Your oil pan a pass side dipstick being a tbi ? The pans I have a drivers side... And ya that would be great if you could throw the t case in and bring it to silver lake. We should have a truck and trailer in the parking lot I can throw it in. Let me know what you want for it.
Unfortunately it looks like I'm no help on your oil pan situation... I want to check out your traction bar setup, I'm going to need to make one for my truck.
