cegusman
3/4 ton status
I see nothing wrong with any of those
Leper said:So what you are telling me, is that when I used a ratchet strap to hold my draglink up, after it bent down to the axle tube while in a ditch, so that I could drive the truck an hour to my house, I should have taken a picture?
supersize75k5 said:
I sheered a centering pin on the front axel one night..
loosened up the u-bolts, used a 2 come-a-longs to locate axel back in place..re-tourqued the u-bolts wheeled it that next day and drove it for a week.![]()
even
big dan said:Im a little embarrased by this but I sheered a center pin one time and didnt know what had happened. when I would drive down the road it would pull to one side and when I would brake my axle would shift causeing some real scarry steering. decided to look at it one day and you could see where the axle had been sliding back and forth on the spring. loosened the u-bolts that were already pretty loose, and jacked up the frame and the spring pack came apart. now I check my u-bolts once a week to make sure they are still tight.
FOR MUD said:I said #2 . I work with re-bar all the time and that is some cheap ass metal , and the import [third world] stuff is even cheaper!!!!I was on that site for 2 1/2 hrs the other night too , had bad dreams all that night.
Exactly!8_YOUR_H2 said:I refuse to vote until you add "all of the above" as an option
Same here ! I'm a carpenter by trade and the only thing rebar is good for is burying it in concrete , not good for use on steering a 4x4 . # 10 was pretty bad tooFOR MUD said:I said #2 . I work with re-bar all the time and that is some cheap ass metal , and the import [third world] stuff is even cheaper!!!!I was on that site for 2 1/2 hrs the other night too , had bad dreams all that night.
. I think all those asshats that built that stuff should be slapped about the head multiple times with a 44" bogger
. That's booty fab at it's best .
