Anyone install headers for the angle spark plug heads on a SBC.
Thank you,
Ed
Thank you,
Ed
X2 on the Heddman Elites, i have them on my 84 Jimmy. Fit my Sportsman II's with angle plug heads no problem.
My Hooker comps I used to have with my small block cleared the angle plugs no problem.
I had a set of Doug Thorely's that fit, but I had to dimple one of the primaries so the boot would not hit. I am currently using a set of Heddman Elite's on the angle plug 383ci, but it is in a 2wd truck now. You may want to check with them because I think I remember them having a 4x4 application.
I'm running the angle plug AFR 180's with a shorty header for a 88-95 truck and they work no problem.
I'm running Flow-tech headers and IIRC they are for 4x4 applications. I'll double check and let you know for sure.
Did your heads have the raised exhaust ports?
And where the headers the shorty or full length type?
Thanks,
Ed
