Angled Zero Rate or EZ Inch?
You should skip looking for those, and instead, check out JKW's angled shims. Basically the same thing, with no custom machining.
Mmm. If he's gonna have a ZR / EZI *anyway*, I'd rather see the thing be milled, as opposed to stacking the ZR/EZI and a shim under the spring.
There was a thread about this the other week, and the stack of stuff involved was mildly frightening. ;) I know that both bolt through the spring pack, but it's still a lot of pieces.
-- A
JKW makes them. I've got some 4 degree ZR's into a true 1" at the thinnest part.
I also had him make some 8 degree ZR's, also with the thinnest part at 1".
