Ok,here's some pics.
When I started this build, I made inspection to body, and it looked to be almost rustfree. I was little dissapointed when I discovered that every crossbrace under the cargo floor were rotting away. Also the rearmost crossmember on a body was totally shot. Notice the excellent condition of the front part of the floor (right corner on picture)
Easiest way to fix this was to remove everything from the rear.
While I was there, I cut off the rear rocker, it gets mangled to rocks anyway.
Then the fun started. I made some measurements to where to cut, and I did it so that there is one horizontal, and three vertical planes after the rear is welded to front. I figured it would take some strain out of the weld seams when they are not in one straight vertical line. Besides, it was much easier to joint the front and rear part when I just lifted the rear on top of the front.
50cm, or 19,7" off.
I used engine hoist to support rear half after the cut. First I placed it under the roof, but it was really unstable and I thought that it might fall to the floor and bend. So I looked for some plate and steel ring, that I cut in half and welded to the roof.
Then I just strapped the hoist to the ring and vóila, safety first.
After rear was aligned with the front, I tacked the lower part of the body, so I could remove the engine hoist. First impression was "Damn, what did I do??", but when I went to the garage next morning, body looked really nice.
Problems arised when I noticed that roof line did not align. First I thought that it was just crooked, and was going to force it in place, but then noticed that it was only the sides, top of the roof was fine.
First I tried to fix it by cuttiing lines to roof, bending them, and the welding. Result was more or less f**ked up roof. Welded part warped, started to resemble a bowl. Also you can see that it bended roof line up. Even though I used pressurized air to cool welding seams, heat still warped everything.
After I considered different sollutions to fix this, I cut part from the chopped roof and tacked it in place.
I relocated the fuel fill to the front of the rear tire. I'm going to mount 16gal Jazz tank to the front of the rear axle, so this was a perfect place for fill opening.
Then I continued by cutting of the rockers between the wheel wells. Thanks to dleroy43 for giving this great idea
I used 150x50x4 millimeter tubing (5.9x2x0.16 in inches). I cut 2" up from the lowest part of the door, so I also had to cut bit over 2" off from the doors. Little extra work, but this way I gain same amount under the rockers if I'd be using 3" bodylift. T-case and fuel cell would need that 3" bodylift, but instead I just raise the floor for those parts. Low CoG rules
Overall, I love the way Suburban looks now.
