another driveshaft/ujoint newb question.
colbystephens
1 ton status
Oregon
ok - so i'm trying to change out my ubolt so i can run the 14bff i have under my rig. after you pull the c-clips, what do you do?
edit - i'm an idiot and meant to say ujoints. i need to swap in the conversion joint and can't figure out how to remove the old one.
I dont know about anyone else but you lost me when you ask about C-clips and changing to 14 blt. If you are swapping axles there is no need to remove the c-clips, just unbolt the 4 ubolts disconnect brakes and e-brake and disconnnet d-shaft. Put new axle under install new ubolts, connect brake line and ebrake, bleed brakes, and install conversion ujoint and reconnect dshaft.
What are you really asking, put it simple I have had a quite a few New Castles:D.
Ira
ok. so apparently i need to figure out what the hell i'm talking about. :) sorry. basically - how do you change a ujoint. sorry, just realized i previously said ubolt and meant ujoint.
If it is the stock shaft the caps are held into the yoke on the shaft with injected plastic rather than a snap ring or clip. You have to melt that out and then press the caps out with a socket larger than the cap on one side and one smaller than the cap on the other.
Ira
