I know I'm going to get blasted for this, but I'm doing it anyway!
I've spent countless hours scouring countless posts on dozens of forums and read countless articles trying to nail this one down to no avail. so, I thought I'd turn to the members of this board for my query. I'm sure this question has been answered many times over and over again but I just can't seem to find it... so...
I have a 78 K5 with a 350 SB and TH350 trans, stock NP203 and stock 10 bolt / 12 bolt axles... when I bought it last fall I drove it home but almost stopped to call a tow truck, it was that scary to drive (and I've driven a lot of junk over the decades!)... I have since replaced every single component of the service braking system and the cooling system, deleting the O.E. cooling fan, opting for an electric fan... this thing sits steady all day long at 190*F... I replaced the stock exhaust with a set of Hooker headers, 2 1/2" pipes, and a pair of Flowmaster 40 mufflers... the lady I bought it from removed the original Q-jet and installed an Edelbrock 1406 in its place... the install was... rough... to say the least... the O.E. gas tank had about 2 gallons of water and about 10lbs of rust in it so I replaced it with a 32gal fuel cell, all new fuel lines, and an electric pump, regulated to 4.5psi with a new Holley regulator... a new Weiand dual plane intake... I replaced the cam with a Comp Cams 12-231-2 cam kit (lifters included) 206/214 duration at .050" and .432/.453 lift... new timing gear set from Comp, also... broke in the cam at 2500rpm for 1/2 hour with Joe Gibbs break-in oil and replaced after break-in with Joe Gibbs 10w-30 and new WIX filter... I installed a new mechanical advance kit from MSD with the lightest springs in the kit and a new Accell vacuum advance... I have initial timing set about 12-14* and total timing at about 40* coming in about 2500rpm... intake vacuum is steady at about 16" hg, no surprises revving it up or decelerating... it runs very smooth (mostly)... new cap, rotor, wires, plugs... everything needed to make this beauty purr, BUT...
it'll sit and purr like a kitten in the driveway... I can rev it up and it's smooth all the way to 4500rpm... but, as soon as I try to drive it, everything goes to pot! when I shift into gear the revs drop by about 500rpm... I live in the middle of a decent sized hill, about a half mile from the bottom and about one mile to the top... I always drive to the top of the hill and by the time I get there, the engine seems to be loaded up full of gas and won't run properly... I have to shift to neutral and rev the snot out of it before I can go anywhere... #8 plug keeps fouling to the point where I've had to replace it... I know the Edelbrock owners manual is available on-line and I've downloaded it and read through it several times... I've used the charts to lean it out step-by-step and have gone out of range on the chart... I'm continually tuning this thing leaner and leaner and I've not yet hit the "lean stumble" I've expected to experience...
I talked to a guy at a local parts store and he says folks using that carb are leaning it WAY down with great results... right now I have .092 primary and .089 secondary with 75-47 metering rods and the 3" (lightest... blue) step-up springs installed... this guy was saying he's seen people regularly use .080 primaries and secondaries with the 73-47 rods and 4"springs on 500+ HP engines
... does this sound right to anyone??? I live at 6200 feet above sea level, but I've seen much richer combos than this described all over the internet even at this elevation and they claim to be working well... anybody got any ideas?
anyway,
