I was hoping you guys could take a look at this. To my very novice eye, I am bouncing back forth between the pattern being good to thinking maybe the pinion is just a tad too far away. These are used gears, I was told to pay the closest attention to the coast side. Thanks in advance.
See the one you posted is more straight forward to me. This is what is in my book from Randy's ring & pinion
The one in Randy's book leaves me a bit more confused. When I pulled the gears out the backlash was at .019 average after checking it on four different spots. After installing the ARB I got the backlash to .008. Makes me wonder if there was a reason the gears had such a rediculous amount of backlash when I pulled them. The guy I bought it from said he a had Geared Up in Grass Valley set up the gears. From what I understand Geared Up is a very good shop.
