skark_burmer
I have a K5 that i want to make reliable, burly, and driveable for long adventures over any kind of terrain that i care to tackle. The stock 10 bolt, 208 and D44 are going out and taking their place will be a 14bolt, 205 and D60, cause i hear those are kinda hard to break.
This will also be a semi daily driver so i dont want to loose too much driveability and will be used for weekend adventures and wont be trailered. Baja, Moab, Tahoe, stuff like that. I'll also be using it for my main transport to go snowboarding in the winter and hunting in the summer so it will see a lot of pavement use too.
I already got the K5 interior to a point that is good enough for now, welded up all the rust spots and had the entire inside sprayed with bed liner.
http://www.coloradok5.com/forums/showthread.php?t=160682
I'll update that post with pics of the inside. the project has been on hold for longer than i care to admit, but now it time to get busy.
Im going to 4 link the front and rear, full hydro steering, high steer, and would like to use air bags but havent figured out that part yet. for the short term i might take the easy way out and use coil springs.
I looked long and hard for a good donor vehicle and came across a suitable vehicle. Im im the process of building up the K30 to wheel the snot out of, then im going to swap the running gear over to my K5 once i get everything figured out. Its going to be about a year before the swap to the K5 takes place. Maybe this summer if im feeling frisky, but i dont think it will happen that soon cause i have too many other projects and hobbies that like to get in the way.
Donor vehicle is a 87 K30 with a 6.2 that used to be a PG&E truck.
Here is the K5 that the axles and xfer case will be going in once im done with the K30
So far i have added some H2 wheels with 35's, Blazenoffroad front bumper and 8724 winch to the front. I yanked the bench seat and installed some El Cheapo "look at me, im a street racer" seats that i got for a song along with 5 point harnesses. So far only the lap belt is installed, the shoulder straps will go in after i build the inside hoop.
The Bumper is super stout but unfortunately it didnt line up too well with the winch and the upper housing of the winch contacts the top bar. I have let them know about the problem so hopefully in the future they will move the winch over to the drivers side a little to avoid contact. I'll have to weld up the holes and cable slot and move it over a little, that project will be added to the thread in the coming weeks.
I took it wheeling a few times and had great fun.
Keep in mind im a total newb to this so my idea of wheeling is prolly a little watered down from some of you guys so go easy on me. The only other wheeling i have done was in a M1 Abrams and HMMWV so this is a learning experience.
This pic is of the truck trying to roll over. Its hard to tell from the pic but the only thing keeping the truck from rolling is the door up against the ground as i drive down a riverbed with 2 wheels in the rut and 2 wheels on the side of the hill.
The truck is stock with a D60 front and 14bff rear. Its got a gov bomb the back and after a few times out the rear end is sounding like a Detriot locker as i maneuver around in the neighborhood. I pulled the diff cover and sure enough, there are some rather large chunks at the bottom which dont look like they should be there.
I thought long and hard about what diff to put in it and decided on a Eaton limited slip. I know some of you out there will think its a dumb choice but the design for the drivetrain is to be under my K5 which is a daily driver and i wanted a limited slip. I realize this will reduce my traction at times but im willing to live with it to get the benefit the rest of the time. Besides the blazer isnt going to be a rock crawler.
I got a ARB for the front and CTM joints that are going in when i rebuild it. I also got the crane diff covers and a set of their high steer arms to use when i tackle the hydraulic steering.
So for the last few trips the rear driveshaft has started to come apart and there is so much slack in the front shaft that i think i could almost pull it apart with a swift kick of a Doc Marten. So i put a call into High Angle Driveline and spoke to Jesse for a good 45 minutes. He coached me through all the measurements i needed to take and we spoke about my design paramaters for the K30 and then the K5 in the future. I decided to get shafts for the K30 now and then re-use/modify them as best we can for the K5 when the swap time comes.
A week later my UPS man is all sorts of pissed off as he makes a delivery. These things are heavier then they look. Pics to come.
the next day he deilvered the PSC steering setup, and from the pained look on his face that was kinda heavy too.
The day after that he delivers the Eaton and ARB and i think he is secretly planning how best to have me killed.
A few days after that he delivers the Evolution medium body heim joints. 16 of them. He is not pleased.
I offer him a beer but i dont think it helped that much.
The last time i went wheeling i got it stuck in a ditch. Front end first and its deep, steep and slimy. Im not getting out of this one. Luckily i could still get to my winch but the cable wasnt long enough to reach anything behind me so i was screwed. It was right then that i thought to myself;
"If im going to go wheeling alone, i need to be more prepared"
I had the standard stuff like jack, spare, hand tools, shovel and that kind of thing but i didnt bring a tree saver or any other winch accessories.
So as i sat there waiting for someone to come along i thought how nice it would be to have a winch on the back. Maybe something that could plug into the reciever and i could just pull myself out.
Well someone finally came along and got me out so when i got home i started on the rear winch.
First thing, order a nice heavy box to annoy the UPS man.
Second thing, decide how to mount it.
Well this has a flat bed on it and the reciever is cheesy to say the least so i decided to change my idea a little. I decided to mount it under the bed to a 1/2" steel plate welded directly to the frame and have the cable come out the back.
I used 1x1" solid steel bar to brace it and the plate is braced on the underside by 2x3" .250 rectangle. Should be plenty stout.
Then i finished off the winch well with stainless steel sheet i had laying around to try to keep the water and mud from splashing all over it.
I need to go to the local metals place and get some aluminum diamond sheet to make a hatch for it but otherwise its done.
Next step, rear diff.
