This weekend i had a little bit of time to work on it. All i got done was the orbital valve mounting.
Ok, so i have no idea how other people mount theirs and i couldnt find any pictures that helped much so took it step by step and just solved the issues as they arose.
first step, ditch the stock steering components.
thats easy enough.
Then i decided i wanted the valve as close to the firewall as possible. Fewer linkage mounting points and all that.
I got a kit from Poly Performance and stuff didnt fit as i thought it should.
This isnt bashing Poly, as i have never done this before, but i figured things are designed to mount in some other configuration than what i had come up with. How they were designed to mount, i have no idea. Also the pump i got is nowhere near the correct bolt pattern to my factory ps pump bracket. I'll need to call them to see what up and if they sell the correct bracket.
Firstly the little adapter that goes from the valve to the steering shaft is a 1" shaft, turned down to 1.75" round. Well, the steering shaft on my truck is 1.75" round with two flats, that are 1.5" and a hole in the middle. I dont know why Poly didnt mill the shaft with the two flats and drill the hole, so i took care of that by myself.
Yeah i know, im no machinist. but atleast it fits and is a snug fit even without the bolt so i think it'll work fine.
Once i had the adapter fitting the shaft i set out to make a mounting base for the valve. Again, with no experience to draw from i just took it one step at a time.
the adapter has 4 tabs on it which make mounting a plate to the face of it a very tight fit. I wanted my mount to be beefy and i had some 3/8" 1018 plate so i was going to use that. I didnt want to mill down the plate to fit between the tabs on the adapter, so i just cut them off.
Here is 3 cut off with one left that you can see.
Then i made a mounting plate to fit the face of the adapter.
Here i am test fitting some parts.
I think im balding a little...
and here is what i came up with.
I was going to weld it directly to the frame, but thought i might need to remove it for some reason in the future, so i added a plate to the bottom that gets bolted on. The frame will be welded to this bottom plate, then the box for the valve gets bolted to the bottom plate.
Sturdy, beefy 3/8" steel, and removable.
Now its time to run some lines!
