DukeBoy88
Just won a NV4500 auction from a guy who did the swap on a 86 long bed. pretty much everything is there including bellhousing,transfer case and crossmember except hydro clutch stuff and flywheel. what other engines used the same flywheel as the 6.2? need to find one for a core charge. Also would like recomendations on clutches, this will be going in my M1008 with banks sidewinder, and I plan on adding an intercooler in the future and hopefully a little more power. I've used centerforce and zoom in cars but this will be my first manual diesel truck. Also this trans came out of '95 truck, was '94 the last year for the lower 1st gear? or is there a way to identify this from the outside? thanks in advance, I'm sure I'll be asking more once I start the install or maybe the rebuild if it needs it.
