Interesting way of doing it. I like it, but are you going to run some extra protection for the T-case as well?
And as for the welding idea, I really can't see a piece of 3/8" (or thicker) steel warping from a little welding, but I also mentioned surfacing it afterwords. That's neither here nor there as I didn't do that or the gasket material, I just used The Right Stuff for it all. Hasn't leaked yet, but if it does I'll go from there.
Odd how much stuff we buy doesn't include directions, they just come from other people's opinions off the internet.
Lifting the box sounds nifty cause it also puts it closer to the driver. If you run a body lift, the linkage angle wont be as bad, so lifting the box or modifying the linkage wont be as aggressive. It took some checking and rechecking before I completed my linkage, but it shifts silky smooth. If the body mounts are questionable, then I guess the BL will have to wait till later.....after you break a few mounts LOL. I love my BL, not just for tire clearance, but the extra room under the tub. Clearance around the trans, frame, gas tank, etc is nice....for working on and cleaning mud out too
