Another question.. what weight oil in differential??
XHitman396
Broken Arrow, Oklahoma
so what weight oil should i put in a 14bff and my 10 bolt front?? Ive never even bought any before, and the guy at the parts store triple guessed himself. so, whatcha got?? thank you..
i use 80-90. some guy who claims to build rock crawlers says that 80-140 or something works better in diffs with lockers. i duno if hes right tho.
70-140, its synthetic gear lube. thinner, Mazda/Ford use it in their tcases(the Ford Escape/Mazda thinger). Yeah I say use 80-90, nothing wrong with it in any instance, just use limited slip additive when you have a limited slip diff.
check and see, most 80/90's have LSD additive.
"consider" 140 if your going to be towing in hot weather. Synth is good, but if you play around a lot in water/mud, you'd be changing it all the time anyways.
so if your plannin on taking a 275 mile trip each way to the beach, it prolly would be best to put in the 70/140 synthetic right?:) i just finished the break in period for my yukons/detroits so i need to change the fluids anyways.
I'd stay with 80/90 the biggest reason for going to a higher weight oil is heat. If you aren't building a lot of heat in your diff (like when you do towing) just run 80/90
for a light-use rig / DD, what would be the best synthetic to use? My ranger has a tiny diff.. couldn't take much fluid and it hasn't been changed (as far as I know!) since it was built in 94...
j
a long road trip would build up alot of heat right? would puttin 70/140 eliminate the need to stop frequently to allow it to cool down?
alright cool. well i only mentioned frequent stops because it was advice that was given to i believe it was avery bout driving like 200miles to the beach in cali.
if you gears are fully broken in, there should be no need to stop all the time. Now if they aren't done the break in period, yeah giving it a break is a good idea.
So, is there any reason to not run 85W140? The manual for my Detroit says to use mfg recommend oil (80-90). The manual for my Lock-Right says to use 85-140 to reduce the noise. Figured I'd just go with the 85W140 in both since I'm in sunny Florida.
