Ck1500
Well i have been working alot on the Blazer as of lately, see "Operation Holy Rust" in the body shop, and been putting in quite a bit of hours at work also. so i get home today and head out to the garage. to do some more metal fab work, and i was busy doing my thing, and had to use the Air Cut-off tool, started cutting away, and noticed my Air Compressor wasnt comming on yet, so i stopped and walked over to it. its a Porter Cable 60 Gallon, 7Hp decent sized unit, and i have had it for about 10 years now. and the compressor came on just as i got up to it, so i thought no biggie back to work, went back to cutting for about 5 minutes and stopped, noticed garage was full of smoke!!!! and not cutting or grinding debris flying around. ran over to compressor just in time to hear the great sound of a rod knock in it. shut it off. and tore it apart "after cooling down of course" and yes its toast. so i remember seeing a replacement pump from Harbor Freight, so i went up there and found it. for 94 bucks. and brought it home, read instructions and removed from box, OMG this thing is HUGE! so i removed my old pump and set the new pump on it. started to figure out what i needed to install it on my current setup. list was some angle iron stock to extend my motor mounts out, a different pulley because the one on the new pump was a 4L style and it was double also, new belt, new oil, and all the plumbing parts, 1/2" compression fittings, to the 3/4 flare thats on the new pump. needless to say after running around town, and locating all the correct stuff at Home Depot, and i walked past a 60gallon 3.7 hp compressor for 400$ then it hit me.. should i be putting all this time and effort into this Harbor Freight FrankenStein machine? or purchase a new one. and have a warranty and alot less labor involved.
wife wants me to buy the new one. and i think i am going back tommarow after work to return all the stuff i bought to make the HF one work. and purchase it.
my thoughts were possibly using my old tank for storage and routing the new compressor into the old tank, is this a bad idea? i know i will have to rework some things on it. but i thought wow 120 gallons of air, that would be HUGE! but will it kill the new one sooner, make it work harder? i know i have to break the new one in, and change oil after like 30 minutes.
any advice would be greatly appreciated guys!!! you have yet to steer me wrong!
thanks
Ck1500
thanks
Ck1500
