I run mine off the dryer hookup - just can't weld & do clothes at the same time!!
That is the only 220 outlet I have in my garage as well
.I run mine off the dryer hookup - just can't weld & do clothes at the same time!!
.MrArmyAnt said:Found compressor on site, title to link is 2 hp, title on page says 6 hp, description says 2 hp, pic says 6. wtf? http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00916734000
nvrenuf said:What about the Lincoln Weld Pak 3200HD ($459 @ Home Depot)? It's suppossed to do up to 5/16's and is gas ready. It's a 120v unit rated at 25 - 135 amps.
Would this be a good welder for a "leaner"? I'm not looking to do heavy work, just junk on my own stuff (like a weld on steering brace, etc).
tRustyK5 said:Infinite adjustments
Duty cycle (higher is better)
Gas ready
length of gun (10' is so much better than 6')
machine brand
Let's be honest, the big name brands are better quality. That doesn't mean you can't do the job with a Clarke or Cambell Hausfeld if you have to, just that if you ran any of the 'budget' brands back to back with a Miller or Lincoln you'd feel the difference immediately.
Rene
