Another63" spring swap question
Yes the front perch of the rear spring is moved foward and down on the frame.[/ ] okay thank you really like how you did your fenders on the rear soon as I figure out how to upload pictures I will show you a pic of mine and where my tires sitting I have not moved my front purchase but did move my rear purchase back with 7 and 1/4 shackles
I'll go a bit against the grain here. On my old 64 swap I used a 4 + Overload pack from a random truck spring shop here. They had 3 different load options, and I can't remember exactly what it was but I went as soft as I could with 4 leaves. I think I remember 190 lb/in rate, but don't quote me. The overload is like a 600 lb/in.
I let my springs over-arch to get the stuff. Ditched the overload, but had to keep the W in check. So I grabbed some old springs from an S10. I can't remember which I used but I pulled a thin leaf out and cut it down. Its arch is very much so deeper than the 64's. I put that leaf at the bottom of the 64 pack just to help the pack keep its arch shape and not W.
I really didn't expect much life out of them. But they made it 5 years before they should have been replaced. While not near as good as something like an ORD pack, its an option that I don't think you should shy away from just because it goes against the matching rules. I was certain the shape-keeper leaves would crack. They never did.
are you on pirate 4x4 it won't let me post pics over here
You'll have to be premium or upload elsewhere. I went with TC 64"s on my Burb Still working out finishing touches and will need to go to a shorter shackle flip.
