I installed the side mount ball whith a 102" whip on the Blazer today. Problem is it sticks out like the simple drawing I made. How can I get it to stick straight up?
What do you mean it gets worse ??dontoe said:Yeah, I did that to install it. If I rotate it now, it gets worse.
Quick and easy would be too tie it too the topper. Use a tennis ball too keep it from making contact with the metal of the body.dontoe said:Yeah, I never thought 'o that. I could make one of those!
I bent the antenna for now so I don't whip oncoming trucks. campers, etc; here's some pics from just after dawn this morning.
rebelk5frk said:You should be able to adjust the whole ball by loosening the nut on the back of the mount. Then use the angled split of the ball to get it pointed just right.
Use tennis ball on ant. So it is not grounding out on body when you talk. I have seen this fry a nice cobra.dontoe said:Oh.......kool, first one I ever have messed with. Thanks man. I didn't know it would do that, obviously.
.dontoe said:I figured it would get tore off, but I know where to get another. So the spring is bad????????
