My mechanic wanted to replace my sway bar bushings since the fronts are 100% shot. The fronts went easy. He took the rears and drilled out around the eyelet and pressed out the bushing and then tried to press the new OEM style rubber bushing. It did not go well. He sent my swaybar to a local Chevy guru with a shop - the sway bar came back without bushings.
For background my K5 has factory springs (original bushings) and has a mild lift from shackles in the front and 3" blocks in the rear. Without the swaybar it handles fine with the soft OEM reverse front springs. I want to keep the swaybar because it helps with keeping speed up around corners (Quadrajet, SM465, 3.08 gears, locker, and 32" tires) so I A) don't have to slow way down for a downshift or B) get into low rpm lean bucking (worse with driveline slop and locker lock/unlock jolt - can richen idle but gas mileage suffers and smell fuel at idle); there is a sweet spot that works and the swaybar helps. The K5 is a daily driver and my wife drives it half the time with the kids. But, it retains the remnants of mods for 38" tires and articulating offroad. If I want to go off road on anything more than fire roads I can remove my sway bar - it is only a few bolts.
There are threads relating to replacing the sway bar eyelet bushing (a decent baseline instructional) - to be clear this is the rear eyelet bushing where the sway bar attaches to the axle. The newer swaybars have links instead of eyelets so this relates to the older trucks.
There are a few schools of thought:
Those that give up and use two-piece poly
Success - those that persevere and have faith
Buy a new OEM swaybar from GM
This raised a question for me - does the poly and rubber perform any differently?
The OEM rubber bushing is a 'caged rubber torsional bushing' that provides resistance (like a shock absorber) when the axles move vertically in addition to the sway bar torsional between wheels. The poly does not provide vertical resistance, it acts like a lubed bearing and freely moves vertically, while the sway bar provides torsional resistance between tires. The answer is yes, the poly and rubber perform differently.
The next question, is there a need for the 'caged rubber torsional bushing' on the sway bar? GM engineers put it there but it could also just have been inexpensive to use rubber.
A few threads on performance -
estimating antiroll bar stiffness (wikipedia)
T=Vehicle track width (inches)
K=Fractional lever arm ration (movement at roll bar / movement at wheel)
d=Bar diameter (inches)
R=Effective arm length (inches)
L=Half length of bar (inches)
S=Length of lever arm (inches)
Q=Stiffness (lb*in per degree)
B = Bushing torsional resistance???
My mechanic gives up and wants me to buy the ORD two-piece poly bushings so he can get on with his life and get my swaybar out of his shop. Of course, I don't need a mechanic to install ORD bushings - I can do that in the parking lot. The only possible complaint about poly - and nobody has ever made a thread on this but there are threads where someone heard of someone that said their poly sway bar bushings eventually squeak; this Reddit thread describes poly bushing problems on street cars and solutions.
Images I took while my mechanic went through the wtf are these the right size process...
Any thoughts?
- a recent ck5 thread
- another ck5 thread (has pics)
- 67-72chevytrucks.com thread
- forum73-87chevytrucks thread - suggestions to shrink rubber bushing with alcohol or freeze
- steelsoldiers.com thread
- chevytalk.com thread that got the NAPA shop to do it - they ruined three sets of bushings in the process
- got it but it looks terrible (ck5)
- ck5 thread left the story hanging - he got them in without the steel insert, but then could not get the steel inserts in - put inserts in freezer and said he would update - presumably it worked and OP never bothered to update post?
- Cannot find it again but there is a post that removed the steel insert, installed the bushing and then made a 'bullet' to guide the steel insert and then pressed the steel insert.
- thread from pirate4x4 (Florida dealership had new OEM)
- technical term for swaybar is 'anti-roll bar' and there is a nice write up in wikipedia with graphics and the equation to calculate the sway bar behavior. The calculation does not include the bushing as a factor - this indicates the bushing type is irrelevant. There is a good graphic.
- a discussion of poly and rubber with good graphics and explanations
- a corvette thread that concludes poly is a better choice for swaybar and motor mounts but is not a good selection for other suspension components
- long discussion on rubber versus poly - a performance car site but they get into the geek of the poly bushing and sway bar and poly versus rubber; too bad there is no clear answer, more of a sales Q/A article
- ORD; lube the poly and it works fine as a sway bar bushing
Any thoughts?
