Rene - you're like Chuck Norris... you dont sleep.... you wait.
as for theft deterrents, removing a master fuse is the easiest thing. My M1009 also has a battery disconnect switch. But both of these are under the hood, and a proper car thief will case your vehicle before attempting to steal it. if you pop the hood every time you park it, they'll figure it out.
A proper kill switch would be inside the vehicle, hidden in plain sight, where someone might not think to look. but in easy reach so that someone observing from outside the vehicle might not notice you use it.
- Ive seen kill switches in driver door handles.
- up under the dash, looks like you're releasing the parking brake when you lean forward to turn it off.
- floor mounted high beam switch repurposed as a kill switch, with headlight switches mounted on the dash, or in the ashtray.
- repurposed stereo buttons
- switches hidden in the glove box
- I had a friend wire his headlight switch like a kill switch. the idea being since daytime running lights (DRL's) are safer anyway, why not make it so the headlights need to be on for the truck to start. This is my personal favorite. As all the modified wiring is invisible. no extra switches to find in hidden places, nothing that stands out as abnormal. If memory served he used the headlight voltage to trip a relay that controlled power to the starter. Most thieves arent going to turn on the headlights before the truck is started to avoid drawing attention to themselves. last I heard the rig had never been stolen.
Of course you could also leave the TC in neutral, as most people nowadays aren't versed in anything involving manual selection of gears. In fact, nowadays carjackers will make the victim drive the car if it has a manual transmission because the robber doesn't know how to drive stick. One of the many reasons I love manual transmission vehicles over automatic slushboxes.
