Yep, large vertical black "box" is the cruise module.
The whole panel to the left of it (with the flasher) is part of the "convenience" center. Some of it is tied into the key off/headlight on buzzer system IIRC. Not sure what the buzzer would be on the fuse panel, pretty sure I don't have one...might be a later deal, even though my panel is pretty much the same as what was used until 1991. Huh.
The VSS also feeds your ECM, FYI.
Yep! They used really tiny connectors on those things.
So you are intending to essentially keep the cruise setup as-is, just changing the VSS input and to electronic cruise?
I am deleting everything from the factory vacuum cruise setup. I am just keeping the wiring coming from the switch, steering column switch and the Trans vacuum / TCC break switch deal.
Pink goes to 12v key +
Grey is the on/ off that from the factory runs to the brake switch, I guess that needs to be re-routed
If you don't mind, I'd like to know what you find out about the electronic cruise motors and how to adapt to this setup. I was at a wrecking yard not too long ago, and saw plenty of the '88+ trucks with it, and I know S10's and F-bodies used them too, at least for awhile. Just don't know when/if things changed on them that would cause them not to work on our rigs.
Sure thing.
As long as your doing an LS swap with a 99-02 that setup should work. I was going to try and adapt my stock 87 vacuum setup but it is just big and bulky and would need a ridiculous cable setup. This is clean simple and mounts right in place.
You need one with a plug in the "H" pin spot. If there is a wire coming out of the "H" terminal it will not work.
Hope its ok to post a link to another forum, but its where I found the info for this. http://67-72chevytrucks.com/vboard/showthread.php?t=511477
About the only thing I know that changed on them was the cable length. Depending on application, some of them I saw were long enough to probably mount the cruise motor on the fender.
I don't recall what mine came off of (still vacuum) but mine is mounted on the auxiliary battery tray...that's quite a reach lol.
Ahhh....thought the module in that hand drawn diagram was "our" stock one!
So the later setup integrated the cruise module into the motor housing? THAT I did not know...NOW it all makes sense.
Since I've got a DRAC, this swap is going to be easy. Wonder if the stock cruise wiring will reach to the engine bay/new module if it's removed from the stock wiring harness bundle?
I've got to strip a bunch of unused wiring out of my under-dash wiring, was hoping GM had snaked the wires up from fuse panel/column up and over, adding a bunch of length to fit. Oh well.
I read that thread, didn't see any reason given why you couldn't use the ones with a plug in the H position. There are enough of these out there that it doesn't really matter, but curious as to what makes them so different.
Can you tell if this is the connector? http://www.electricalhub.com/media/...9eda06f020e43594a9c230972d/1/2/12065425_3.jpg It sure looks like it. I've got to place an order anyway, I've gotten to the point of just making the wires anymore instead of soldering where I can. I just haven't messed with the "newer" stuff enough yet to know what all connector series they are using. If there is a part number on the connector, that would help too. 12065425 would appear to be the right connector PN, FWIW.
Thanks!
