Would it be easier to pass inspection with a TBI engine? Or is it easier to tune for passing the inspection with a carburetor?I believe so. It has to pass a smog test and visual inspection.
I believe it is supposed to be original, pretty sure it is similar to California, if you want upgrade to newer, it needs to be inspected first for having all required equipment then the sniffer testWould it be easier to pass inspection with a TBI engine? Or is it easier to tune for passing the inspection with a carburetor?
The visual is the main issue for having to add it. Now if it actually works or not isn't the question, but visually its supposed to be there. Most of the kids working at the state emissions places wouldn't know the difference.Would it be easier to pass inspection with a TBI engine? Or is it easier to tune for passing the inspection with a carburetor?
If the carb is in a good state of tune and the engine isn't blowing oil out in the exhaust it shouldn't have too much of a problem to pass. But it still has to pass the visual.
Does it have to have the factory air cleaner and stove pipe as well?
It’s a shame people hack up the emissions systems for no real return.
Martin
Want an aluminum intake manifold?
Martin
