Any fix for the plastic tank on an aluminum radiator?
HarryH3
1 ton status
Author
Georgetown, TX
Has anyone discovered a magic elixir that will seal a crack in a plastic radiator tank? One of the tanks on the radiator in my S-Jimmy has a small crack in it, but all of the radiator repair epoxies that I've found don't list plastic as something they will stick too. /forums/images/icons/mad.gif GM wants $66 for a new side tank, plus $48 for the gaskets! /forums/images/icons/shocked.gif If I can't find a cheaper way to fix it, I'll just buy a complete radiator. It's only a few bucks more! This radiator appears to be in fine shape other than this crack, even though it is 11 years old.
A radiator shop can install a aftermarket tank for less than that I'll bet. May as well have it rodded out too...
Jim
Hey Harry my name is Jason and I own a 1983 6.2l K10 Blazer (Diesel) When I got the blazer I noticed it had a crack in the radiator over flow tank, it would leak so much that I had to fill the thing every other day. /forums/images/icons/mad.gif I know how you feel cause I couldnt find any radiator tanks at the junkyard and the price for a new one was outrageous. I finally got mad enough and got a tube of cheap superglue I got at FredMeyer and pached it that way. The weird thing is......IT WORKED! /forums/images/icons/shocked.gif Just clean the surface real well then hold the crack together and start pouring it on. It takes a while and AOLT of super glue, once one layer dries put another one on and so on. I superglued my hands together a few times but it was worth it. Well I hope this helps any, it worked for me, let me know if it works for you. [email protected] -GOOD LUCK!-
It's possible it may be hot air welded, although I've never tried it in that application. Depends on the type of plastic it's made out of. Most of the plastic I notice on vehicles is either ABS or poly, which is pretty easy to weld, but I'm not sure on a rad side tank. If it's a composite of some sort, forget my idea /forums/images/icons/tongue.gif , and replace it.
