Any Gm techs
oatsk5
Grand junction CO
I have a 2003 2500hd 6.0 crewcab. The trailer brakes only work if i manually engae the unit tek voyager and not when i use the brakes on the truck. My old neighbor said there a red wire that sends the signal that goes bad. I want to know if its is somthing i can fix or if i should have the dealer handle any info would be great
Oh sorry if its not puncuated sp? correctly
Sounds like the brake input to your control is not working.
The following information is for the 2003-05 wiring harness.
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
Brake controller illumination
B
RED
242
Brake controller 12 volt source
C
DK BLUE
47
Brake Controller output (Trailer Brakes)
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
