losenj
Registered Member
getting ready to throw in the ez inch just wondering what problems people had moving the axle forward the 1.5". 10/14ff with 1' body 35's
If you are running a shim, you might think about sending the EZ Inchers back and having Kert cut the degree into them. Make sure he knows which way you plan to run them. This is what I did on my fronts, 5* cut into the block instead of running shims. Much better
push pull stock steering might not like it .
I have read some guys have to modify the drag link a lot.
That's the biggest CON to the blocks is running a shorter draglink.
Wait, how did it get longer?
lol hold on, I understand how you made it longer, but why was it necessary to make it longer. I would think moving the axle forward 1.5", which is towards the steering box, would also make the draglink 1.5" shorter.
what am I missing, I can't picture it any other way![]()
and how did you correctly get the threads to clamp the sleave ?
there 1 left and 1 right thread for the sleve / turnbuckle to work .![]()
ruffstuff punches holes 1" each
kirt @ diy4x slots .
I thunk you ment he center hole was slotted .![]()
