Oh yeah no worries! damn dirty slots!
wooooo
don't talks to a professional hooker like that . I washed my tow truck bed today . its all clean . . .. but wet as its raining tonight .
so do i need the shims in for pinon and caster angle or should i be fine withoutYou can bolt the shim to the center pin on the block, then the pin's head goes into the perch on the axle. The offset pin goes from the block, up through the leaves, and fastened with the nut.
Ignore the shim on the top. In this pic, you can see my block is tapered. If it wasn't, the shim would be bolted to the block via the center bolt. The center bolt (since I have it offset forward) would only be holding the shim and block together. The center pin is what goes into the perch to help hold the axle.
The offset pin (the one that goes through the leaves) bolts to the other offset hole in the block.
On mine, the center pin is only there for the axle. It's only 1/2" long and holds nothing together.
You'll need to check caster angle and get it between specs. ATM I don't know what that is. Don't worry about the pinion angle. For some reason 6-8* sounds good in my head.
so how do i check caster angle thanks for all the help and info
I've got a few ez inches in the shop and have been curious about using them to extend the wheelbase on my K5 by moving each axle outward an inch. Would I run into driveshaft issues doing so on a four inch lift? Could I use it in the rear with my 2" angled block?
ya good question and what about the steering shaft
I was thinking that moving the axles out on a four inch lift might be the point that stock driveshafts are a bit too short, then I remembered it would also lift it an inch.
I understand the feeling about stacking blocks, I once had shims and blocks and did not care for that, although it never gave any trouble.
Seems like you need to sit down, think about what kind of truck you want, and then ask all your questions. This "shoot from the hip" question routine is going to get old, IMO.
What are your plans for the truck?
*A body lift will require you to extend the steering shaft from the column to the steering box. 1" BL is easy enough to do. Using an XJ shaft (please search if you don't know) will help if you plan to do a BL.
