any ideas?
Randy92782
1 ton status
Arcadia, MO
ok so i bought a truck. took off the front and rear diff. covers to see if maybe the gears matched. here's what i found. here's the front
thought it was a locker but have no idea what kind?
here's the rear
think maybe it is a limited slip. thanks for all ya'll's help
pretty sure the gears are 4:10's but here's the numbers
Front- 3 3 82 Dana D 18520 A30295 45 11 <<that's why i said 4:10's
Rear- 1 GM _74014 9 37 2 83 <<not sure about rear
limited slip in the rear for certain. Can't tell on the front, any closer pics?
and is that a lift block on the front?
yeah unfortunately it is a lift block on the front. it's gettin removed. if u only saw what they had as a lift in the back. they had 2 four inch lift blocks stacked.....yeah kinda what i thought. talk about dangerous and stupid.
i call gov bom rear. as it looks like it has the fly weight shaft in it. and the front possible old style power lock or trac lock of some kind.
I would say gov lock or G80 locking differential for the 14bff, and maybe the Dana is the Powerlok.
Your front axle is a Dana 44, 4.10, and either an early Auburn gear limited slip, or early True-Trac---Both good posi's.
Your rear axle is a 14 bolt semi-floater; That is to say the axle shaft is NOT full floating, as would be a 14 bolt full-floater
4.10 gears, and a gov-loc--not a very desirable rear end, and a rather weak form of limited slip.
Jimbo
