Any pics of the Bushwacker Cut-Out Flares?
this is way back in the day.
stupidest things i ever bought /forums/images/graemlins/mad.gif, they are long since cracked and destroyed, and removed.
Fender flares arent worth the material they are made of. They do a somewhat good job of keeping mud off of the side of your truck, but are big pieces of crap imho. They are overpriced, and if you ever happen to rub them against a tree or rock, they will crack and destroy easily. Dont waste your money on them.
-Harrison
I've got them on my burb. I've already replaced the front ones because one of them split. When they break again it will be an excuse to just /forums/images/graemlins/hack.gif the fenders and go with bigger tires /forums/images/graemlins/rotfl.gif
/forums/images/graemlins/shocked.gif ... so you guys just recommend straight cutting then and no fender flares at all? i need more room mainly up front, the 35"s rub when the wheels are turned in either direction going up into anything raised above the ground really...no problem if wheels are straight. anywhere i can read on or recommendations for how much to cut?? this is for now, just making enough room for the 35"s and to go offroading and not rub.
well, now that you've asked for my opinion....
those flares suck hardcore. i cracked mine with body flex, they never even hit a tree. they were the most expensive pieces of plastic i've ever bought. right now they are sitting on a shelf in my garage. pm me if you're interested.
to answer your question, just keep trimming until the tires dont hit, and then make the other side match
[ QUOTE ]
[/ QUOTE ]
read here
I put them on my rig because I run 44"x18.5 wide swampers and the Local Doughnut munchers like to give out tickets for the tires sticking out past the fenders........
thanks for the link. yeah the one bad thing i have noticed not havin them, in the winter time since the front fenders are a little narrower and the tires stick out, it sprays the road salt all over the sides. it turns from a black truck into a white one if its not cleaned off.
