VW aluminum head.Is it that hard to do, I see they have kits with the tap and coil specifically for spark plugs. Can I do it with the head on and vaccuum out the hole afterward???
, go to amazon.com tools&hardware spark plug rethread tool KD ToolUncle Fester said:did you strip out the hole or just cross thread it? IF it is just cross threaded, I found a tool that you put down in the hole, expand it and then retap it from the inside out...starting witht the good, uncrossed, lower threads.
http://www.shop.com/op/aprod-p32147665-k24-g4-~spark+plug+tool-nover?sourceid=13
if that link don't work for some reason...my links never seam to work right, go to amazon.com tools&hardware spark plug rethread tool KD Tool
this keeps you from having to remove the heads.....
..might be a good idea to yank the heads anyway though,if a valve job is due...--all of my VW motors blew up the same way-- when the #3 exhaust valve decided to behead itself,and it went thru the piston,and wedged between the crank and the case!
..and I was pretty anal about keeping the valves adjusted properly--guess the first owner wasn't!..
