anybody running 2500HD wheels?
beater_k20
Banned
Elkhart, IN
i've been kicking around what wheels i want to put on my 92, i dont want something big and gaudy, but i dont want steel either. i kinda like the looks of the H2 wheels with 2500/3500 center caps on them, but then again, i like the looks of the 2500HD wheels even better. anybody running them on a set of 70s 3/4 ton axles? i've got a D44 and a 14FF going under the truck. also, what are the dimensions of the wheels? width, BS, etc?
supersize75k5 is running the hd wheels. the h2's are 17x9 i believe... with 4.5" of backspacing... This is from memory though so double check:crazy:
they are 16x6.5 wide. I sell the trucks new. last time I checked they don't fit over the hubs.
They fit over a 10 bolt/ 44 which is what he needs...unless supersize modded his
he wants to put them on a 14 bolt. they fit on a 10 bolt no problem because it has a flat mounting area. no hub sticking out.
10 bolt front... the axles supersize is running are 10/ 14 bolt.
Also these rims come on 2500 hd's which have the 11.5" ff axle:rolleyes:
My friend had the HD wheels on his K5 for a while with some 36" bias Iroks. He has a D44/14 bff from a late 70's K20 under his K5. The wheels bolted on with no problems. The rear wheels looked too "tucked in" for my tastes, but the bling bling from the aluminum looks awesome. We only with they made them in a 16x10 size.
well, i'm now out on the HD wheels. 6.5" is a little narrow for my taste, and i thought they were 17s. H2s it is.
lol must have posted at the same time, also im running a 44 not a 10 bolt
Same differance:p:
