Gaffed
I've found tons of people who have clocked there transfer case and are pimping 4"+ of lift. Has anyone clocked a transfer case flat on a stock suspension truck? I'm planning on doing a zero rate in the rear and a 1" body lift. Then clock the tc flat and for a belly pan. I'm not going to get to start working on this until mid-february due to work. Its on my 241c.
Could I possibly get away with using the stock front driveshaft with clearancing only? If length is an issue how about just adding a small spacer?
Thanks,
Chris
Thanks,
Chris
