Anyone done a 4 door S10 blazer on a K5 frame
k5-newbie
Huntsville, Texas
Thinking about my next project. 4 door S10 on a full size frame with d60, 14FF etc, etc. Anyone done this or have some pics or a link?
01000001 01100110 01110100 01100101 01110010 00100000 01110100 01101000 01100101 00100000 01100110 01101001 01110010 01110011 01110100 00100000 01100100 01100101 01101110 01110100 00100000 01101001 01110100 00100000 01100001 01101100 01101100 00100000 01100111 01101111 01100101 01110011 00100000 01100100 01101111 01110111 01101110 00100000 01101000 01101001 01101100 01101100 00100000 01100110 01110010 01101111 01101101 00100000 01110100 01101000 01100101 01110010 01100101 00001010
eh?
It's super secret computer language that says after the first dent it all goes downhill from there.
mikey_d05 said:
All you did was wrinkle a door :p:
LOL, just thinkin ahead for when I want to get smaller... the Blazer is not even finished yet, it has ALOT of wheelin ahead of it. It may just end up like most of the others, with a frame, cab, and tubes, but that will be after the body is almost unrecognizable.
Like I said, just thinkin into the future, very distant future. I dont want to go jeep and dont want to go yota...so S10 is about the only thing small that Chevy makes, unless I get a good deal on a Geo :D :eek1: :whistle: :hack: :grind: :weld: :yikes:
LOL
About to start on similar type vehice at the end of the month. It will keep stock frame as it is same width as fullsize. I am waiting on a set of axles(14bff and Dana 60). I am using 6 inch lift fullsize springs all around and ORD 2 1/2 rear shackle flip with daystar shackle for front as well as lowered front spring mounts that will come off of a burban I am going to part out. Thinking of a doubler or one of those XPENSIVE new Stak “Monster Box” T cases. It is only a 2 door blazer though.
Entropy, the first law of thermo dynamics..........it can only get worse! :D
Check out WhiteKnight for an S10 project gone extreme!!!!
a guy on here use to have a s-10 truck cab on a blazer frame i believe. His name is Yeild2me
If you search under his name you will find some stuff..
