Really hard to tell from this pic, but the belt is way too close to the lower hose, and cuts it.
It hits above the hose clamp, so I thought it would self clearance, but apparently the vibration(?) is enough to cause a leak. Didn't get a chance to play with it much before I had to shelve it for awhile, there is a possibility the leak is unrelated I suppose.
Same set of accessories for decades, only change is recently I re-routed the v-belt as previous it was only on the water pump (edit: crank pulley, not water pump) and it seems that wore the bearing out. But it was on the pump only because of this clearance issue. Never ran the belt this way before, as I foresaw the issue, but would rather not have pump failure from belt routing. Obviously same problem, two different pumps.
Off the top of my head the crank and water pump pulleys are off a Monte SS, maybe the alternator pulley too. Power steering pump who knows? They all seem to line up well.
Just can't figure out what SBC application would have been able to run that crank pulley, that close to the water pump, and not have the issue I have. I checked, the Monte uses the same water pump as the K5 (at least according to rockauto) so the hose should be in the same location regardless.
If I cut the "excess" hose back it might clear. Still seems like a weird problem to have to deal with.
Given the chance the leak is related to the hose clamp, is there a "best" clamp under $50 that is a known quantity?
