my brothers 6.5 just took a dump. He needs his truck for work, and hasn’t had any luck finding them decently priced. Does anyone have a good one laying around? Will travel for right price.
All truck versions of the 6.2 and 6.5 are pretty much the same. If he finds a good engine but it has the ds4 pump he can use just has to change a couple things. The timing cover housing is different as the mechanical engines don't have an optical sensor. SO you can just use the cover off his old engine. And of course the injection pump is different.
Otherwise it's swap all external parts over to the "new" engine and run it.
The differences are minor. If his mechanical (DB2) IP is in fine shape I would simply swap it as @KirsL said. If not, I would grab the whole harness from the DS4 donor (with the ECM and PMD). A newer engine will also come with a newer turbine (like the GM8). The interchangeability of all the parts gives you a lot of options.
Good to know. Intake and everything is the same? Or do we have to swap that too?
Would the GM8 be a better turbo?
Agreed x's eleventy thousand!I second having the pump and injectors checked out since the engine is down.
I wish you guys weren't so far away, I would give you a good long block.
I got a couple leads on some 6.5's. Let me do some checking.
I have no idea. Both popped up within a couple of days.Where were those leads a couple months ago?![]()
