Mine is leaking super bad around the throttle shaft seals, would prefer to avoid having to spend big dollars having the IP rebuilt...
I do have a 93 6.5L IP sitting on shelf, I understand that is the desirable pump for a turbocharged engine, what would need to happen to use it? Just turn down the fuel a bit? My current IP will produce plenty of black smoke till the turbo spools up as it is.
How's it all running for you otherwise?
