Anyone making front 52” leaf spring hangers
It’s not body sway, it’s spring sway
I had 3 leafs in the back and could go 80 down the highway
Also k10
This is a trail only truck, the only highway it will ever see is if I go from one track to another that I don’t have it trailered.
I want the leaf springs with 52’s in front because it’s a cheap alternative to coil overs and I need the vehicle operating before I move. I’m moving states and if it can’t roll I’m gonna have an issue.
Anyway bottom line, because the 52’s will work for me.
They worked for me too. In conjunction I used a 58” spring in the back.
I went off that article, used 7/16” grade 8 bolts, and added a few other pieces in there for support. It’s been installed 10 years no issues
you may have already seen this; I personally don't know the difference in the mounting between the 67-72 and 73-91. I do know the overall spring is shorter.
I had a Blazer on 57s out back and S shaped them the first trip
