anyone run tranny atf fluid in the np205?
I somehow doubt it.Fordum, I'm glad you posted that. I've been wondering why in the world a manufacturer would want to put ATF in a transmission or transfer case that has gears instead of the guts of an automatic where a lot of slippage is going on. The manual trans in my 2000 Ford F-150 uses ATF and it stopped shifting worth a crap after it was a couple of years old. About once ever couple of years or so I'll go out there and drain it and put in some fresh ATF (it never looks burnt or discolored) and it will shift slightly better for a while, but then it goes back to not wanting to go into gear smoothly again. I've wondered if switching to normal gear oil will make it shift better, but after what you posted, I wonder if heat will be an issue. The Ford trans has an aluminum case vs. the iron case of the NP205. Don't know how much that would matter.
That's kind of why I haven't really seriously considered trying it. I've thought about going down to the dealership and asking someone down there who seems to know what he's doing about swapping it over, but I don't think I trust even them on something like that. Guess I'll just keep the ATF. Bad shifting is better than a locked up transmission any day.
with a TH350 NP 205 in the event that the seal leaks it is better to have atf. I would rather have leaking atf into the tranny then gear oil
I'm pretty sure that most of the 205's came from the factory with gear oil and only the later syncronized 205's used ATF.
...automatic hubs.
Hmm, I may have just answered my own question.....
