Stuck at work. Limited internet. Truck cranks. No start. Has spark, no fuel. Fuel pump relay "clicks". Can't access diagrams. Can anyone tell me what color wire feeds the fuel pump?
Thanks!
Thanks!
If you are thinking about replacing the pump, I just did it. Did not need to drop hitch....only the skid plate. Then used two come-a-long straps and a floor jack to lower the tank down. Just work it down slowly.
I don't have the filler plate between the tailgate and the bumper. Pretty sure you can't get to the skid plate or tank strap nuts/bolts without it being removed.
What I do is unbolt the front bolts of the skid. Pull the front end down (bend the rear of it a bit) and then remove the rear skid bolts. It will come relatively straight down. Put together in reverse.
Unless your truck is miraculously rust free, or someone has done this recently, this is not likely going to be an easy job.
You can siphon fuel out of the tank from the filter if you need to, but it will be slow. Easier to deal with the tank if it doesn't have 30 gallons of fuel in it. I have found it is relatively easy to sit under the truck on the passenger side in front of the rear axle, looking backwards, to disconnect the fuel and vent lines. Don't forget the pump wiring/ground.
I use a floor jack under the tank to kind of assist. Still a pain. But undo the straps on the back, then let the tank drop a bit. That will give you some access to the fuel fill hoses. They are normally a bear to get off, but resist cutting them unless you have already sourced a replacement...the large one is fairly uncommon and tends to be stupid expensive.
You may have just split the hose in the tank, but I'd replace the pump while in there even if that is the only issue. Not many choices for "excellent" quality pumps, Delco's probably your best bet, but still no guarantee based on what others have mentioned. I've not had bad luck so far with them.
FWIW, the red wire hanging off the fuel pump relay is where you put 12V from the battery to test the pump. That bypasses the relay.
On a Blazer if you lower the tailgate, you have clean access to the two rear tank strap nuts.
Well the skid plate removal was a non issue. 3 bolts from the top (tailgate open) 3 bolts from the bottom.
Did not remove hitch (yet, it's only 4 more nuts) looks like I might not have to.
Strap's not double nutted.... is that an indicator the tanks been down before?
So do people pull the hitch to ease the removal of the shield, or tank?
