Anyone using a Klune-V
DesertDueler
Phoenix, AZ
I was wondering if anyone is using a Klune-V in there truck? Or if anybody knows who is using one? I was thinking of using one in the Jimmy instead of a doubler since it will have a lower crawl ratio than the doubler, but I dont know if its as strong as the doubler
86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
DD,
Have you seen the "latest"? An ORD Doubler with a Wrangler Products 3.6:1 Gearset for the 203?
That will give you a 7.2:1 ratio, a 3.6:1 ratio and a 2:1 ratio.......I think the Klune is good for about 5:1 maximum.
Granted.....you'll be "into" this setup for close to $2000 (Doubler Kit + Gearset) but it sure seems like a COOL solution.....especially if you have "useless" crawl ratio axle gears like me (3.73s).....That 7.2:1 makes up for a LOT and I still have a great highway cruise RPM.......It's kinda like having O.D. without buying a new transmission.....
Anyway, just a thought in case you hadn't already seen it.
-Greg72
'72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
<font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
Yea I saw the new low gears for the 203. As for the klune-v it takes you low and multiplies it by 2.7. So with my 208 it would put it in the 7 range.
Hey what is this Klune-v ? Is it a gear reduction? Where does it go and how involved is the install?
Need input!
Rob <a target="_blank" href=http://community.webshots.com/user/yellowmoon72>72 blazer 4 inch lift 35 tires</a>
WOW! your lucky I wish I have low gears like tha I only have 3.07's
LOL
From what I've seen it is an inline gearbox, like adding a second Xfer case to the mix so you can 'double' your gear reduction and make your rig drive like a tractor. All RPM and no SPEED, a rock crawlers wet dream!!
72K5
Led Zeppelin
Rock ON!
<a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
The Klune uses a planetary reduction gearset like the NP241 does. I'm building one right now
to go between a NV4500 and my NP205. The project is currently stalled due to lack of cash but I have all the parts I need. Hopefully I can get back on track soon.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
Rene...So what exactly are you building?...a 241/205 doubler?
The nice thing about the Klune is you can shift on-the-fly.
The bad thing is that it won't handle the torque of a strong motor behind a granny gear tranny (ie: 465 or 4500).
'71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
<a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
I'm building a small gear case housing a 241 planetary behind the NV4500, then it goes into the NP205. I see no reason the 241 planetary wouldn't stand up to a small block and a granny gear. The 241 comes stock behind the NV4500...
I recently scored a 32 spline NP241 for $120 and I'm looking to get the mainshaft shortened and resplined. The case itself is pretty easy. I'll have to convert my 205 to a 32 spline input though, but that's no big deal.
Available ranges will be 1:1, 1.96:1, 2.72:1, and 5.33:1.
Rene
Sounds fun! I hope you put up the plans when you are done (or sell them). I might have to think about that setup...
I'll take plenty of pic's etc. Basically a write up of sorts for whoever is interested. I just got recalled back to work after a short lay-off so if I can get some overtime in I can get back on track with it soon!
My goal is to have it all done and in the truck before Moab...that way I can explode D44 axles with style and authority!
Rene
Hi Rene,
It's Rod. I am glad to hear that you are back at work. I just tried your link to your pics and I didn't get anything. Is it just me? I really want to see what you have been up to. Are you going with a full convert? You sold my buddy Kevin your old tub. James and him came out to pick it up, unfortunately, I was busy that day. Send some pics, I am dying to see what is up!
Take Care,
Rod
<font color=orange><a target="_blank" href=http://community.webshots.com/user/72blazerod>My Picture Pages</a><font color=orange>
Thanks Rod,
My link is to the members gallery which is not working right now.
Here's another link to the same pictures...
<a target="_blank" href=http://community.webshots.com/album/17169539OIDZxbkaDa> tRusty pic's</a>
I might go to full convertable with tRusty...I have two 74 toppers now plus a 74 to use as a guide and template. I guess it all depends on how motivated I get. I want the mechanical's done first and then I'll decide whether to chop or not to chop.
Rene
